Mercedes AMG F1 W08 EQ Power +
F1Krof
94
Re: Mercedes AMG F1 W08 EQ Power +
NathanOlder wrote:
07 Jul 2017, 20:52
Precautionary change due to damage sustained in Baku. The Vettel incident ??!!??
They banged the front wheels, and the shunt wasn't that much of an impact to destroy the gearbox. But tough luck man, Lewis'
Wroom wroom
itwasntme
itwasntme
F1NAC
169
It's sad that someone actually thought of that...
ClarkBT11
Why do we dump Mercedes team thread stuff in the car thread? It's happening every week #-o
bm150
bm150
cplchanb wrote:
07 Jul 2017, 19:14
It was quoted from Merc that they had brought a new nose FW and floor to Austria.
Can anyone spot the differences??
:D 8) :idea: need more hi def close ups..
ClarkBT11
cplchanb wrote:
07 Jul 2017, 19:14
The yellow arrows on the pictures on the previous page points most of the differences.
Under the nose on the end of vortex generator
Mirror​ stalks
Vane on top off floor
atanatizante
115
1. Those vertical strakes carved into the leading and trailing edge of the FW are new as Motorsport.com is saying?
2. Why is that carbon fiber fairings divided there? Coz one is for the drive shaft and another one is for the lower wishbone? Then why they didn`t create a big single one fairing simulating a kind of lower rear wing over the crash structure, like they have had in the past? Having 2 fairings would help them in adding DF maybe?
Jesus
roon
roon
412
atanatizante wrote:
08 Jul 2017, 18:07
https://s2.postimg.org/b11b9mfy1/2017-0 ... h-2017.jpg
There is a prescribed maximum height/length ratio for suspension arm cross-sections. Two short-chord arms will be thinner (less frontal area) than one long-chord arm.
mycadcae
Pls explain , what is this?
Regard,
Nik Wan, Mechanical Designer, CATIA V5/ Solidworks/Autodesk Inventor/ AutoCAD
RicME85
52
They are some sort of fixing/pin, Scarbs mentioned them a few weeks ago, something about Mercedes always go to scrutineering with them out like that.
morefirejules08
morefirejules08
Does anyone have an idea what Mercedes are trying to achieve with the new mirror stalks?
CLKGTR
CLKGTR
100
morefirejules08 wrote:
09 Jul 2017, 20:57
Lower drag coefficient, smaller frontal area and better airflow towards the rear, as always when it comes to mirrors. Visibility is not a priority here :)
But very impressive and detailed work from Mercedes on this low-benefit aero element.
theWPTformula
50
roon wrote:
08 Jul 2017, 18:49
atanatizante wrote:
08 Jul 2017, 18:07
I believe the regulations also state that there must be five individual/exposed connections to the upright (2 upper wishbone, 2 lower wishbone, 1 pushrod/pullrod) but no minimum number at the gearbox, that's why the fairing is partially split. For the front upright it's six (2 upper wishbone, 2 lower wishbone, 1 pushrod/pullrod, 1 steering arm).
roon
roon
412
theWPTformula wrote:
10 Jul 2017, 13:30
roon wrote:
08 Jul 2017, 18:49
atanatizante wrote:
08 Jul 2017, 18:07
Also, now that they can alter the arm AoA +/-10°, it becomes feasible to make something akin to a two-element wing.
Via@AlbertFabrega
