Good to be back though, event hough the GP was really bad without the drama at the end
Don't you get the point that Albon is in front of Hamilton at the apex of the corner and when they are at the acceleration phase, he has the driving line and is entitled to it not the car behind. Albon didn't have to leave space even though Lewis has 3/4 of empty track to his side, yet Albon was as close to the kerbs as he can be without compromising his exit.siskue2005 wrote: ↑05 Jul 2020, 18:21https://scontent.fcok4-1.fna.fbcdn.net/ ... e=5F2614B0
Yup, not enough room for Albon and he didnt get it!![]()
That means they were side by side, you might want to learn the meaning of "ahead" in racing parlance. If you are not fully ahead, then by definition you are sibe by side. Albon was attempting to overtake and therefore the rules dictate he must do so safely, and that means giving proper racing room, he did not and ran over HAMs front tire with his rear tire.JordanMugen wrote: ↑05 Jul 2020, 17:45You might want to double-check whose rear wheel (Albon's) was hit by whose front wheel (Hamilton). That suggests Albon was ahead.
Yes, but the second time Albon was AHEAD.NathanOlder wrote: ↑05 Jul 2020, 18:53Would also like to add, the very same 2 cars went intot that very corner side by side on lap 1, this time with Hamilton on the outside. What happened.......... LEWIS BACKED OUT.
this was my next comment, they would have crashed on the first lap at the same plaxe had lewis not backed out massively, Albon left him zero room at all compared to the space Lewis left him in the second incident.NathanOlder wrote: ↑05 Jul 2020, 18:53Would also like to add, the very same 2 cars went intot that very corner side by side on lap 1, this time with Hamilton on the outside. What happened.......... LEWIS BACKED OUT.
barely! He was ahead from higher corner speed, how is Lewis supposed to alter his trajectory mid corner effectively? He cant, if albon is goin to go steamin around the outside and accelerate past on the OUTSIDE he should have the awareness that the driver on used tyres is likely to be at their grip limit to defend.falonso81 wrote: ↑05 Jul 2020, 18:57Yes, but the second time Albon was AHEAD.NathanOlder wrote: ↑05 Jul 2020, 18:53Would also like to add, the very same 2 cars went intot that very corner side by side on lap 1, this time with Hamilton on the outside. What happened.......... LEWIS BACKED OUT.
I never said it wasnt legal. I said it’s a challenge, because the inside line gives that driver the edge in regards to position and defense. If you are on the outside, you are always vulnerable to the car on the inside moving outwards. It’s simple physics. Not to mention last year it was deemed to be a viable “racing maneuver”.Sevach wrote: ↑05 Jul 2020, 18:18Albon is trying a move around the outside because it's risky but legal, he did under the assumption Hamilton would give him room and the knowledge that "pushing a guy wide" isn't part of the rules.Phil wrote: ↑05 Jul 2020, 17:56That is what happens when overtaking cars on the outside into a corner. There’s a reason why it’s more difficult and thus why pretty much every driver with half a brain will defend the inside of a corner. If Albon has the balls to attempt a move on the outside and at the risk if being pushed wide, he is also accepting it. This isnt anything new.
You are always going to be vulnerable when going around the outside.
There's a lot of gray area on "how far alongside" you have to be to be entitled to have room, but we can both agree that Albon was more than far enough "alongside" to get it.
Which is why i say Hamilton deserves the penalty he got, tough break for Albon.
I know this. But as you probably know, we're not talking about speeds of 250+km/h, this was 80-120, somewhere around this range. The lock on his FP3 lap was done with 71 km/h, which is his apex speed. Also, you can check the steering lock Bottas applied on the last corner of his pole lap, which is quite a lot similar to the lock Hamilton applied today. I don't know the concrete speed, but he took it in middle revs 5th gear. I'd say quite a lot faster than what Hamilton did today. You could say it's due to race setup, onboard fuel and tire wear, which is true - and this is exactly why he should've backed off, just like Norris did when Leclerc overtook him.NathanOlder wrote: ↑05 Jul 2020, 18:49You need to understand how steering through a corner works first buddy. Lewis would be on the limit of adhesion (limit of grip) If he adds more lock , the car understeers more. You dont just turn more to go tighter. The cars are on the limit, the front has no more grip to give, If it did, he would have gone faster. Turning the wheel like you want him to would mean the contact with Albon would have been greater.tpeman wrote: ↑05 Jul 2020, 18:05I watched the onboards. I don't think by providing criticism I am a "hater", it is generally a very overused word. Anyways, here is some footage from his FP3 lap and the moment of the accident. So you say a difference of around 10-15 degrees is "full lock".
Also, I'd like to point out that Albon was heading for the kerb, which obviously isn't in the direction of Lewis.
Full lock
https://i.imgur.com/4Byov8Y.png
Lewis' lock during the incident
https://i.imgur.com/4Bn5Ygx.png
Edit:
Fixed images not showing.
