Ferrari F10
timbo
timbo
111
Re: Ferrari F10
triart3d wrote:2nd: WHO is FIA technical engineer?
GILES SIMON
Is it correct? I though Simon has FIA role now.
raceman
Re: Ferrari F10
GILES SIMON
Gilles Simon is working for FIA in the engines and electronics department.
raceman
Re: Ferrari F10
triart3d wrote:3rd:Ferrari F-duct by Gazetta
shoulder-activated??? :roll:
Re: Ferrari F10
JohnsonsEvilTwin wrote:
even with 2 upgrades the Renault is still slightly off Mercedes and Ferrari.
Simple as that.
lol
JohnsonsEvilTwin wrote:but the reality is its you who has NO IDEA!
you too
Informed opinion suggest Mercedes lead Ferrari in terms of power and consumption... ONLY JUST.
Renault consume less but also have less power.
Cosworth lag behind these.
informed opinion bla bla bla
no one, except the insiders, knows exactly where is the Renault engine in term of power. And many of them have a complete different opinion than yours
They are not as silly as that bitch christian horner...
disagree if you must but dont come with the guns next time....
stop telling bullshit and stop that ridiculous attacks and noone will come with the guns...
autogyro
autogyro
Re: Ferrari F10
No, the hole is there so that the Ferrari drivers can fire those little black foam balls that Button uses at the cars behind, in an attempt to hit the following drivers visor strips.
The word Malboro will be attached to the little balls in reverse print so that the image can afix itself to the following drivers visor.
It is called subliminal paint balling.
JohnsonsEvilTwin
Re: Ferrari F10
Simple as that.
lol
you too
Ok please can you quote the "attacks"?
Seems to me like you confuse debate for "attack" in which case you really ought to lie down and take a chill pill.
If you really think The Renault is the equal of Mercedes and Ferrari then you have a screw loose brother.
Nowhere is it known factually, but the proof is in the pudding right? And since when has anyone said Reanult had the Best engine?
Speculative? yes. But then so is your little tiff you posted...
More could have been done.
David Purley
imightbewrong
imightbewrong
Re: Ferrari F10
tok-tokkie
tok-tokkie
37
Re: Ferrari F10
That hole that Gazetta is speculating to be part of the F-duct. Would it not be covered by the removable side piece of the cockpit? It may be part of the latch system for that bit or it may be a duct that then couples up with a continuation through the cockpit side bit.
imightbewrong
imightbewrong
Re: Ferrari F10
Except for the missing barcode, they have now made the gills bigger, reaching down further on the side of the pods:
madly
madly
Re: Ferrari F10
Barcode craziness.... It's good that Ferrari marked missed barcode area with bold white line. "This is advertising area one of our titular sponsors, but we can't put here even white-red barcode"...
raymondu999
Re: Ferrari F10
Interesting. That's the old engine cover sharkfin no? It has no f-duct piping in it. Or at least it looks flat. Also, it looks like they've gone for a force india-esque mirror mounting from their flow conditioners?
失败者找理由,成功者找方法
donskar
donskar
Re: Ferrari F10
timbo wrote:To this date since 2006 EVERY engine manufacturer did some upgrades.
So, if Renault updates its engines, it's fine, if Ferrari -- no.
I see perfect logic here!
+1
Or, to put it another way, Ferrari purposely blew those engines and gave up points in order to be allowed to make some changes . . . Tin foil hats all around.
JohnsonsEvilTwin
Re: Ferrari F10
Donskar
Seriously have to ask the question why are the engines this year, which are intrinsically the same as last years, so unreliable?
What you are saying is that the engine is just unreliable installed in the F60?
So Ferrari need to change it because of this?
That really is a crap excuse. Its shite in the C29 Sauber too. And its shite for reasons that Ferrari know well. They did somthing, and instead of UNDOING it, they ask for a "reliabilty change".
Do you seriously think that its an innocent "reliability change"?
David Purley
zgred
Re: Ferrari F10
madly
madly
Re: Ferrari F10
If F-duct intake is in such a place, will it be passive system? Am I right?
