BAKf1
BAKf1
06 Mar 2023, 18:43
Jozsusz wrote:
06 Mar 2023, 18:42
Can someone tell me please how good is Merc's wind tunnel compared to the other teams?
It's the same one Aston Martin is using. Plenty good enough.
Aston used RB's general sidepod design last year, then waited a year and added the RB floor and perhaps some other concepts they found using Merc's wind tunnel and increased CFD time... And they are still around .6 in single lap and almost a minute off race pace of RB. Thus, the Aston situation supports what Merc has been saying about it not being helpful to just copy RB's design, because you still end up behind them and a year further away from their understanding of the design. This means that RB will be dominant in the way Merc was between 2014-2020. If that's the case, the best AM, Ferrari and Merc can hope for is second best. This is why it makes sense that they didn't want to go in the same design direction as RB, but it definitely doesn't answer why they stuck with a design that they said would go at the front of the factory to remind them how bad it can get. Which leaves the key question: Is there either a fourth design philosophy that is faster than RB, or can they spot a modification to RB's design that RB have missed?
BAKf1
BAKf1
Or does it not matter what the design is, because the Merc engine will never work as well as RBs?
chrisc90
06 Mar 2023, 19:30
chrisc90 wrote:
06 Mar 2023, 19:23
Do AMR and Mercedes have their own software for evaluating the results too?
Which results? Windtunnel? Telemetry?
Surely there will be data to correlate between the CFD/windtunnels.
chrisc90 wrote:
06 Mar 2023, 19:38
06 Mar 2023, 19:30
chrisc90 wrote:
06 Mar 2023, 19:23
Correct, but at no point is that data in the possession of MGP.
A lion must kill its prey.
chrisc90
06 Mar 2023, 19:40
chrisc90 wrote:
06 Mar 2023, 19:38
06 Mar 2023, 19:30
So I take it they run their own software programs for the wind tunnel and get their own sets of data for it?
So Mercedes could configure the tunnel 1 way, AMR the other. The results of the tunnel get spat out into each teams OWN software for analysis.
Mattchu
58
Do people not realize that Daimler AG (Mercedes parent company) have a large holding in Aston Martin Lagonda PLC. Tobias Moers, the ex head of AMG Mercedes is now CEO of Aston!
Merc have had their run in F1 and all the publicity that goes with it, the "brand" the bigwigs are pushing now is Aston Martin as can be seen by the safety car changes and factory/people investment.
If you think it`s all Lawrence Stroll behind this, think again, the full weight of the parent company is behind Aston and not the team that carries its name but is two thirds owned by Ineos and Wolff.
They`re now pretty much just another team making up the numbers, in my opinion Aston Martin will take their place in the top three and when the next concorde agreement comes round, just before the new engine regs (2026) I wouldn`t be surprised if the team gets sold or Daimler pull out completely.
The top engineers/people aren`t there anymore and haven`t been for a few years, Think Cowell(engine), Costa(design+engineering), Vowles(Srategy), Braun(Technical),Lowe (good with suspension), Lauda(all round good egg). James Allison steping back a bit and being replaced with Elliot can`t have helped either, I really don`t get a good F1 vibe off the bloke, he seems nice enough though, maybe that`s half the problem!
JordanMugen wrote:
06 Mar 2023, 06:47
PlatinumZealot wrote:
06 Mar 2023, 00:52
I have an idea to add a sweeping undercut to the zero-pods.
The sidepod has to go straight down to the floor or be convex (outwards) in order to legalise the SIPS wing. If there was an undercut (concave curve) to the sidepod, the SIPS wing is not legal.
It's not possible to have an undercut and keep the SIPS wing.
Start it after the SIPs wing. Simples.
mendis wrote:
06 Mar 2023, 07:09
Has Mercedes messed up their Suspension or was it just a setup issue? Their tyre life has been screwed. The long run data suggested as such in testing and the race yesterday clearly exposed that. Last year, it was their major strength.
Little bit of rear downforce was they are saying. Means poor traction so less tyre life. Bahrain track exposed this more too.
chrisc90
06 Mar 2023, 20:40
JordanMugen wrote:
06 Mar 2023, 06:47
06 Mar 2023, 00:52
You cant. The view from the front would contain 1 too many shapes. Your only allowed a maximum of 2.
chrisc90 wrote:
06 Mar 2023, 20:42
06 Mar 2023, 20:40
JordanMugen wrote:
06 Mar 2023, 06:47
It would not pass any more curves than RedBull or Ferrari.
Count how many curves on a cross section of this side pod..
chrisc90
06 Mar 2023, 20:44
chrisc90 wrote:
06 Mar 2023, 20:42
06 Mar 2023, 20:40
It would not pass any more curves than RedBull or Aston uses.
It would though. Go re-watch Kyle Engineers video and see the reason why.
See my post edit above.
chrisc90
06 Mar 2023, 20:50
Different legality box id imagine. I’m not even sure how it would work/look even if they could do it. If the legality box for the intake scoops is say 450mm from the front for example , then you have to include your SIS/mid wing into that.
I already have a model so I'm quite shocked to hear esteemed members of this forum deny that it's possible.
chrisc90
Care to annotate where the legality boxes are in regards to the current setup they have?
Even so, if they maintain that SIS, it can only have 1 plane that goes down to the floor. It would just be a major obstruction trying to flat a engine cover out after your bodywork to keep the mid wing legal. It would just be a huge obstruction in the airflow.
