How do you create a accurate engine exhaust flow in the wind tunnel?
Brian
Robbobnob wrote:id assume Red Bull have a system that is modelling resonably well, such a pitty they are winning and dont want to share their secrets.
I'm no aerodynamicist, I think a water tunnel can be useful for designing upper body elements of a F1 car. For the underbody, a rolling road is required. But I think liquid may actually be a better medium than air for aero analysis. You can turn a aero model in any yaw angle you want as long as the pool in large enough and the flow channel is wide enough. Flows travel up to ten times slower in water than in air and allow for more detailed observations to be made. But a rolling road in water is not going to be practicable.hardingfv32 wrote:The teams have a hard time getting data that accurately correlates with on track data using 60% models with air as the medium. How can the data possibly be better using water or any liquid?
What sort of temps and flow are we talking about when we scale to say 60%? Can we expect this scale exhaust flow to have a good correlation the the actual exhaust flow?
Brian
