I hope a few of you will bear with me concerning a safety issue that has me perhaps overly concerned. NASCAR had a rash of airborne cars that threatened to defeat spectator safety. My inexpert analysis suggested that, when a car reversed direction at high speed, the rear wing generated enough lift to elevate the rear of the car enough to, in conjunction with the front air dam, create a powerful ground effect sufficient to elevate the car above spectator safety barriers. The switch back to a rear deck spoiler appears to have remedied the problem, though blowout panels in the front dam might be a good idea.
Aero-rich F-1 car appear to have similar concerns. We know that they will fly forward with a pitch rotation when the front wing attains a lift-generating angle of attack. I suspect that bad things would happen if they were to get backwards -probable on the grass at high speed. While the big rear wing would be a big lifter, the wheel wake would seemingly shield the front wing. Rear-moving undercar dynamics get a bit more complicated, at least for me.
A number of lift-killing devices come to mind once a hazard is recognized. Any thoughts as to the validity of this concern?
