g-force_addict wrote:How about a mouse like sensor than measures ground speed?
For the traction control/ABS.
It is perfectly possible for all 4 wheels to be sliding at the same speed while braking thus temporarily fooling the ABS.
This sensors could also detect lateral sliding.
Not all ABS systems are alike. Some are "cheap" replications of ABS and sample at slow rates and the sensors have low resolution. Hence the "chances" of four wheels sliding and fooling the system.
More expensive systems (ALA Mercedes,BMW, Porsche) sample at much higher rates and the sensors are approaching racing quality (Porsche uses the same sensors on their GT3 cars as they do on the street.)
The biggest developments, for racing are rewritten software codes that enhance street systems and can make the ABS system work on solid ice.
Current technology for lateral sliding (in racing) of the tire is an optical sensor which measure the lateral ground movement at the tire contact patch, one per wheel. Used with the other sensors on the car -Lateral G sensor, one front one rear on the lateral axle lines, GPS heading/speed/racing line again one antenna front, one rear., steering input , ride height (laser) and four wheel (hall effect) speeds, internal tire pressure/temp sensors.
They use them in combination for analysis of the slip angle. There isn't really one simple solution for live measurement, IMHO...
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
