So exactly how do you build flex wings? Lets go beyond the normal "laminate orientation" answer.
First, let us assume that the bending is not linear or maybe has a knee in the curve just after test range.
Can a laminate design create non linear strength? Roughly how would this be accomplished?
Could there be something physical in the structure that could meet our goal? Some way to change the strength of a truss to be non-linear also repeatable?
Brian
