Why does Red Bull have better performance in qualifying than the rest of the competition, yet equal performance during the races? To reduce some forms of disagreement let's assume the above statement is factually true and we remove the quality of the drivers from the discussion.
So what can be done to improve qualifying at the possible expense of race performance?
I wonder about the qualifying weight distribution and Red Bulls aggressive use of the DRS during qualifying. There is also the issue of the KERS battery placement that is obviously problematic. RB might be new to KERS but the battery suppliers know how to treat the batteries and would have informed the team. They have put their batteries in a bad thermo location for a reason. Could it be weight distribution?
How does the qual vs race fuel load effect weight distribution? The rules seem to imply that weight distribution is not controlled during the race.
"For 2011 only, the weight applied on the front and rear wheels must not be less than 291kg and 342kg respectively at all times during the For 2011 only, the weight applied on the front and rear wheels must not be less than 291kg and 342kg respectively at all times during the qualifying practice session."
What is meant exactly by "qualifying practice session"?
Brian
