http://www.uqm.com/propulsion_specs.php
And that got me wondering what sort of performance could be achieved in a light-weight kitcar...
I've looked at the Powerphase 125 which gives peak power of 167bp -quite typical of a middle of the range internal combustion engine in a kitcar... The advantage of this and the Powerphase 145 (194bhp) is that they rev to 8000rpm, so can use the kitcar's standard final drive ratio and still have a decent top speed.
Motor weight = 41kg
controller weight = 16kg
The main problem with electric propulsion is the battery weight, however for the branch of motorsport I'm interested in (UK Sprint/hillclimb events) the runs are short; typically about 60 seconds.... That means that the battery size can be kept to an absolute minimum. With current lithium-ion battery power densities you're looking at a battery pack weight of about 40-50kg...
50+41+16 = 107kg about comparable to 2 litre internal combustion engine and ancillaries. But it gets better... the Electric motor has much higher mid-range power, so it can deliver excellent performance without the need for a gearbox...
Seems to fit into the car rather nicely:-
And has pretty good acceleration performance (compared to the same car with a typical 164bhp internal combustion engine):-
