Hi,
I was wondering if anyone knew how f1 cars are able to reach such high revs? What would happen if a road car had this many revs? Is it the difference in revs due to the complexities of f1 cars?
thanks
Gabe
Yup I understand your confusion and now thinking about it there is something wrong with my calculations...I'm going to re-edit them...and correct them! I did the calculations only analysing the piston going up or down, not a complete revolution! This means that I forgot to calculate the time for half a revolution.....which is half the time of a complete revolution! Sorry to all about the mistake!Different Guest wrote:You are talking of a displacement of 42 mm, gettimg me confused - do you mean that the stroke is 42mm?
This formula is also incorrect!!!! hehehe...sorry people long day with a flight mechanics test....2 labs...and a long night of studying! I'm very sorry...I'm going to crrect everything at one!A=sqrt((0,042*2)/0,00317465)
The peak acceleration of the piston in a F1 engine is a bit more than 90k, maybe up to 95k m/s2, for a road engine it varies a lot (obviously). Taking for example two excellent units, the one on the BMW M3 (6 inline, 3246 cc, b/s 87/91 mm, power 252 kW @ 7900 rpm) and the Ferrari 360 Modena engine (V8 3586 cc b/s 85/79 mm, power 294 kW @ 8500 rpm), for both the maximum piston acceleration is in the order of 38-40k m/s2.piry wrote: what are the g loads aplied on the pistons of an f1 compared to a road car?
I know what you would write and I know you're right....there are a whole lot more variables in between and I can't do exactly what I did...with all the assumptions.....but using simple day-to-day physics it's a relatively interesting numberReca wrote:Monstro : I can’t write what I think about your calculations, use your imagination.
