Hello,
from many suspension geometries I have seen so far, the most common srategy for antidive and antisquat is to create an angle between suspensions mounts line and ground so that the bottom mount is lower than the forward mount.
Now, it seems that is an usual design principle to do it in the upper arm while the mounts of lower arm remain parallel. This will also help to increase caster when the wheel moves upward. Correct ??
But I have also seen some designs (Dodoge Viper - rear suspension) where the angled mounts line is on the lower arms while the upper arm remain parallel to ground.
Is it correct to say that in this case the caster angle descrease in a steady corner ? what are the main difference to achive antidive / antisquat working to the upper arm mountsrather than the lower arm mounts ?
I hope that it make sense....
