I was just thinking, if it makes sense to use cooling fans in order to minimize radiator inlet area.
Do you think that the aerodynamic advantage will compensate the loss of engine power?
I actually thought of only one opening of this size.Tomba wrote:You will also find that the combined inlet surface on that old Jordan Peugeot is not less than what you can find on the sidepods of current F1 cars.
If you are talking about that Dyson air multiplier thing, it still has a fan its just hidden and only does part of the work. Efficient but still banned.Paul wrote:How about a bladeless fan? Feed high velocity air to the intake to create lower pressure and draw more air in at low car speed, when the natural flow is high enough at high car speed you can turn whole system off. Would that be efficient?
