Running a gearbox upside down?
010010011010
010010011010
Hi,
Maybe a stupid question, but I was wondering what would be the problems with running a gearbox upside down.
Basically the car in question runs an Audi transaxle, but the drive comes from near the bottom of the box, causing us to run quite a large angle on the half-shafts, which can be severe on the universal joints. The only weakspot in what is a bullet-proof reliable car.
So if I were to turn the Gearbox upside down it would potentially solve this, and allow greater adjustablity on the rear setup too. Other than maybe somewhere for the oil to gather at the bottom I cant think of much other problems, but im sure there are.
Thanks
A13EX_f
A13EX_f
Re: Running a gearbox upside down?
flipping the gearbox will result in the car going the wrong way
Caito
Caito
Lol'd at A13 response.
I'd take into account lubrication problems.
Come back 747, we miss you!!
flynfrog
also how do you plan to work the linkage.
010010011010
010010011010
The car going the wrong way is an easy fix...
The linkage is a pain but ultimately do-able, I can move the gear lever to the left if needs be, im from Ireland so were used to driving on the left anyway!
The lubrication is the one im really not sure of, since oil isnt necessarily pumped around it its not as if ill be starving the gearbox of oil, but then again I dont know
olefud
olefud
79
010010011010 wrote:The lubrication is the one im really not sure of, since oil isnt necessarily pumped around it its not as if ill be starving the gearbox of oil, but then again I dont know
With no actual knowledge of your transmission, I would guess it's a splash system and might well work inverted if the new lube level allowed for enough lube to provide cooling and a reserve. But if you're going to all the mechanical effort it'll take, why not save a little drag, i.e. dry sump the whole thing? You can probable find an output shaft on which to mount an eccentric to drive a pump and gravity for the drain back. A few well placed nozzles would suffice for distribution, though you could also drill the shafts.
