Aero near walls?
raymondu999
Aero near walls?
Hey folks; I've just been rewatching the 2007 Season Review DVD; and when it came to the part where Lewis was talking through his Indianapolis 2007 pole lap; you could see that on the straight; Lewis; after getting his exit onto it; steers away from the wall. Lewis says "I had to pull away from the wall because supposedly it makes a big difference to the aerodynamics"
What aero effect would it have, do you think?
失败者找理由,成功者找方法
Richard
Richard
Re: Aero near walls?
I imagine it would make a difference to front wing outwash if it is a long wall and very close, and if outwash was significant for car handling at the moment (ie drag v downforce).
However, I thought outwash only assumed current significance with Brawn GP in 2009?
raymondu999
The front wings back then were "in"wash, if that's a correct word
失败者找理由,成功者找方法
strad
117
DRAG...The boundary of the wall creates drag...sorta like side drafting
Sir Stirling Moss
munks
munks
strad wrote:DRAG...The baoundry of the wall creats drag...sorta like side drafting
I'm not an aerodynamicist, but that's what I've been told as well. Driving next to a wall is basically like driving next to an identical (mirrored) car.
Dragonfly
Dragonfly
I am quite away from aerodynamics but IMO the car pushes a significant amount of air, like a wave traveling at the same speed. Eventually it interacts with a nearby wall causing some disturbance and affecting the car asymmetrically.
Spa 2012
rjsa
rjsa
51
And at high speeds the wall will suck the car in.
bill shoe
bill shoe
151
Here's a less technical explaination.
A car far from walls will push air around both sides and over/under. If you are close to a wall then you constrain one of the side flow "options" for the air. This means some of the air that previously found it easiest to go around that side now has to go around the other side or around the bottom/top.
Any flat surface near the car reduces airflow "options" and therefore increases drag. Almost any race car shape with a resonably smooth bottom (i.e. any modern F1 car) would have less air drag if it moved through the air (at zero pitch/yaw) without a ground plane.
scuderiafan
If you watch the Indianapolis 500, the drivers all go down the middle of the straights, because it does not restrict the flow of air around the sides of the car.
"You're so angry that you throw your gloves down, and the worst part is; you have to pick them up again." - Steve Matchett
Patiently waiting...
raymondu999
So from what I'm hearing; it's kind of like there's a reflection off the wall, or a standing wave?
失败者找理由,成功者找方法
sknguy
sknguy
Like risa's and bill shoe's explanations, I thought the wall created a low pressure side force (like downforce and drag) between the car body and the wall. You create two areas of low pressure. With Indy cars I'm not sure how they race on ovals but that's my understanding.
jon-mullen
Let me see how this explanation goes over...
Picture the car's relative velocity is zero and the air's moving at some free stream velocity before it hits the car. The wall's also moving at that free stream velocity. So, the velocity gradient on the side of the car with the wall would have to be much larger than on the side without the wall. Larger velocity gradient means more shear force. That puts an unbalanced force on the side with the wall and tends to rotate the car about its CG into the wall.
...right?
Loud idiot in red since 2010
United States Grand Prix Club, because there's more to racing than NASCAR
strad
117
Hmmmm
Related I think..
click photo for video
pop quiz
Why did I pick Juniors picture?
Sir Stirling Moss
