mPPE wire insulation
modified polyphenylene ether (mPPE)
thermoplastic used in F1?
http://www.alphawire.com/~/media/Files/ ... 20fnl.ashx
Giblet
Giblet
Re: mPPE wire insulation
So that accomplishes the same physical protection and cable insulation duties of the old cable?
Before I do anything I ask myself β€œWould an idiot do that?” And if the answer is yes, I do not do that thing. - Dwight Schrute
Yes. It's lighter, tougher and higher dielectric strength. It should be good for KERS too, since KERS is high voltage. Maybe they are already using it in F1. Would be good for someone to confirm it.
