F1 suspension leg
crog73
crog73
F1 suspension leg
Hi Guys as you can see i am a newbie here and i am trying to find help and information on the history of the materials used in the manufacture of the f1 suspension i have trawled the net for hours and nobody seems to talk about this stuff so i thought i would kindly ask u guys for any help u can give i need to discuss the difference in materials costs ease of manufacture performance all the usual stuff
much appreciated...
mep
29
Re: F1 suspension leg
What is a suspension leg?
The title shoud get changed to something that makes sense.
To answer your question about materials used for suspensions:
Steel, simple as that. Still used most non F1 race cars.
For F1 carbon fibre, often with titan parts bounded to them.
E86
E86
Re you talking about the pushrod? or control arms? Like mentioned before, they are made out of steel(aero tube for open wheelers) or Carbon Fibre in F1 with steel or Ti ends. I hope this helps. There is a great book on Suspension of Racecars from Simon McBeath, look on Amazon.
Best Regards,
Eric Cantore
Team Pelfrey Racing
scarbs
scarbs
393
Wishbones used to be made of steel, constructed by welding a mix of tubular (round or aero profile), machined and fabricated sections. Tyrrell did run a CNC machined aluminium rear top wishbone back in the early eighties.
Teams have run welded Ti wishbones too; this has been mainly for thermal reasons such as the element being in the line of the exhaust plume. Although Renault did switch to a rear Ti wishbone after a failure of a CFRP wishbone at Silverstone.
By the nineties teams were wrapping the wishbones and pushrods in carbon fibre, partly for aerodynamic reasons and partly for stiffness increases, especially with the pushrod.
The natural progression was to create a hybrid element made from carbon fibre sections and Titanium end fittings, the joint being both bonded and mechanically fastened. Development was rapid in this area and teams soon found it was best for QA/NDT reasons to have the Ti end fitting inserted into carbon section.
Jordan were probably the first team to run a completely carbon suspension element, that is the flexure and leg of the suspension element made from as a monolithic structure.
Although teams still have smaller metallic fixings inside the wishbone for mounting hardpoints and often the entire outboard end is still a CNC machined Ti part. But this tends to be only for the higher loaded wishbone, i.e. Front bottom wishbone outer ends.
Construction of the carbon fibre ‘leg’ sections has developed since the nineties too. From two part mouldings bonded together or monolithic parts from a closed mould using air bags to consolidate the plies. Nowadays I understand the closed mould approach is still used, but the pressure comes from a slightly oversized rohacell core, which applies pressure to the plies when the mould is closed.
Although the shift to CFRP has improved stiffness, its more lightness that’s the benefit of a material change. These stats from a F1 source reinforce this fact.
Steel 100%
Carbon with steel ends ~50%
All carbon ~40%
There are other benefits, although in F1 terms a CFRP wishbone does not have a lifing problem (i.e they only have to last 1 season), as the part does not suffer from fatigue like a metallic part will. Additionally using flexures on CFRP wishbones reduces the cost of the spherical bearings teams will work through over the course of a season.
Of course the offset of these benefits are many fold and are the reason other formulae do not use CFRP suspension elements. Firstly cost the tooling will cost tens of thousands of pounds for each wishbone. Make the wishbones unique to each corner and that’s eight sets of wishbone tooling, plus the pushrods\trackrods. Any dimensional change over the season will force a new set of tooling to be made.
Then the QA issues are immense. Although the CFRP element will not fatigue, any damage or overstressing of the part will render it useless. Teams conduct exhaustive NDT to each wishbone: i.e. stress tests, acoustic measurement, Ultrasound. This takes time and resources.
I’ve a load of this info and a bit about flexures to put on my blog over the winter.
conni
conni
In my experiance most teams dont use rohacell as the scrap rate is so high and as for the costs well they are expensive as it would take one person a month to make a set of wishbones for one car and they are lifed as the flexures eventually give up and split
teams get through a set every other race on average unless crashes occur
and they are tested with a 6tonne load put through them
conni
polarboy
polarboy
Mclaren were the 1st team to run a carbon suspension part on a car but only used it in a qualifying session,team lotus were the 1st team to run a carbon part (front pushrods)during a race
