F1 water reservoir
PaulB
72
F1 water reservoir
Hello guys,
does anybody knows where the water reservoir for the driver is? In hot races such as Bahrain or Malaysia, they take about 1,5 litres water with them. That takes a volume of 1,5dm³. Where they store that?
Cheers,
Paul
"Being second is to be the first of the ones who lose!" - Ayrton Senna
Paul Bischof
Milton Keynes, UK
MK2 2HL
http://paulsf1.wordpress.com/
michl420
michl420
19
Re: F1 water reservoir
I think I remember, that the reservoir is stored in the nose, besides the brake fluids reservoires or maybe the pedals.
Hallo Landsmann!
allstaruk08
allstaruk08
im sure coultard said when he was racing it was above the fuel tank and would get quite warm.
manchild
manchild
http://www.formula1.com/news/technical/2005/745/179.html wrote:The usual system to provide this has three elements. The drink reservoir is placed low on the side of the cockpit, so as to prevent it raising the car's centre of gravity. It usually contains around two litres of fluid (which means two kilos of extra weight at the start of the race). A pump, activated by the driver via a steering-wheel switch, sucks the liquid through a tube and to the driver's mouthpiece inside his helmet.
yener
[img]http://www.formula1.com/wi/full/ta_arti ... 79.jpg[img]
2 kilos of extra weight lol.
The minimum weight of a car is set incl the driver.
When he thrinks the water he will still have the 2 kilo "extra weight" :lol:
Reason: Removed image quoted from post above
"Life is about passions - Thank you for sharing mine" MSC
Nickel
Nickel
Not quite that cut and dry actually, he will sweat much of the fluids he is replacing, some of which will stay in his racing suit, some of which will evaporate.
