Good post Raptor22,
Now, this is "your" thread, so you will layout the rules, but if I can make a suggestion, I would recommend to look at each possible scenario, one at a time.
Maybe starting with "pitch" [control], as this seems to be the main idea behind the different RRH systems proposed. This includes the now banned Lotus-Renault
system, as well as the "rumored" system of Mercedes [and perhaps others].
Later you can expand this line of thinking onto roll, and other conditions.
Otherwise, I feel we will have a load of "cross talk", and it will be difficult to follow the debate [for some].
So, I take it from your post, that one aim is, to control the height of the front wing, in relation to the ground, under different conditions, e.g. low speed vs. high speed, and braking vs. acceleration &/or driving a constant speed.
This is a good start - IMO.
Now I´m thinking about the following point:
Raptor22 wrote:
2) changes in pitch also result in a sudden change in the shape of the tyres contact patch. This creates disadvantageous wear patterns relative to a car which does not exihibit dive tendencies
Is the change in pitch really the cause for the change in tyre CP size/shape?
Or is there another reason for this?
Following this line of thought, can a suspension (in this case I mean the combination of springs/dampers, not geometry as in camber change) affect the "shape/size" of the CP?
And if yes - how does this work?
