For acceleration/braking you need almost zero static camber with zero camber change.
To compensate body roll during corner you need a lot camber gain.
Solid axle suspensions provide almost zero camber change when accelerating/braking but horrible bump steer.
Swing axle provides great camber changes when cornering but horrible (and very dangerous) camber changes when accel/braking.
Double wishbone provides moderate (but just not ideal) camber changes when either accelerating, braking or conrnering.
Do you know a suspension type -even if overly complicated- that maintains optimum camber when accel/braking or cornering?
Preferable a passive suspension systemotherwise it would be banned as failure prone.
