hardingfv32 wrote:banibhusan wrote:Well teams are currently allowed to test in a 60% scale WT. Scarbs just reported on twitter that they allowed to trade 4 days of 60% scale WT testing with 1 day of full scale WT testing, either straightline or windshear. Something that Lotus is planning to do.
There are no WTs that test at 100% scale with the same accuracy as a 60% model WT. They would never make such a trade.
Brian
http://www.lotusf1team.com/Shear-Power- ... turns.html
A small reference for you. I dunno how far it's accurate in terms of statistical figures, but it certainly is worth a shot as Lotus have previously used it and they found it beneficial.
EDIT: An excerpt from the above link
“The wind shear test is an aerodynamic simulation carried out at a facility in North Carolina, USA. Here we use a full scale wind tunnel, which allows us to replicate airflow over a real car to see how it behaves. It’s a very useful, controlled way of analysing the car in its current configuration to compare data with our 60% wind tunnel and CFD facility. It also provides a good opportunity to try new upgrades on the car and predict how they will perform.”
“Preparing the car for this test is quite a big task. Firstly, we have to fit hydraulic front and rear suspension which automatically alters ride height, removing the need to constantly make manual adjustments. This is a new system and will have to be pre-fitted. The car will also have a special gearbox installed which has a dummy diff allowing us to spin the wheels freely. Finally, it will be covered in electronic sensors to pick up all the data so overall it’s a lot of work, and a significant transformation from the standard car.”
