Just as there is a absolute temperature minimum, should not there also be a maximum temperature with no physical way to exceed this?
How can this limitation be described?
If temperature can be related to atomic movement then the maximum temperature could be reached when this movement reaches the speed of light.
And as there is a minimum pressure should there not also be maximum possible pressure?
This might be limited by a value when the atoms come so close to each other that they start to touch. But what happens then? Will it be possible to compress them even more bringing them to merge into each other?
Will the atomic movement stop then?
Is this then related to very high temperature, or to cold as cold is usually related to little atomic movement?
Can the maximum achievable temperature then be limited by a maximum pressure where the atoms constantly touch each other?
