Tim.Wright wrote:Steering feel is a massively subjective thing which is not so easy to quantify. It will be difficult to find reliable information on this without talking to an expert on the matter. I'm far from an expert, but can throw my 2 cents in based on what i know of road car systems.
My understanding is that the feel and feedback is the reason teams run hydraulic assistance instead of electrical. This seems to be the reason in road cars too. Hydraulics are so preferred that McLaren for example run a hydraulic system in the MP4 12C but the use an electric pump for the hydraulics instead of running a fluid line from the engine in the rear to the front. It would be easier just to use the electric motor to give the servo assist, but they prefer to have the assist through a hydraulic means.
In terms of response time, if you make the torsion bar quite stiff and run very high pressures with a lot of fluid velocity, this will minimise the response time.
Tim
I'm confused.
In road cars when you turn off the power steering pump, for example when turning off the engine, steering becomes overly heavy much more than an identical car without power steering.
Thus how can reduced pump pressure provide feel without steering becoming unbearable heavy?
Do you guys have some tech info on the F1 power assisted rack and pinion?
