Big Sidepods?
outer_bongolia
Big Sidepods?
Hi All,
I am no areodynamics engineer. I have a question that has been bugging me for a while.
Why don't the teams try a huge (maximum size allowed under the regulations) sidepod with a huge intake?
Before flaming - I am thinking of a sidepod that is designed as a wind tunnel to send the airflow to the back and send the air out of a big hole in the back with a perfect location and direction. They will be mostly empty with some inner surfaces to guide the airflow. The radiators are small enough now - they can be crammed into a corner where they will not affect/block the flow. This structure would also hide a portion of the front of the rear wheel, reducing its negative aerodynamic effects (one could even cut holes in the sidepots to push some air to exit above and around the rear tires). These huge intakes would also take in some of the disturbed air from behind the front wheel and make something useful out of it.
I have been looking at the amount of work that the teams are putting to get the perfect flow around the cars' sidepods to the diffuser area and was always confused why they didn't use a tunnel...
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
FW17
169
Re: Big Sidepods?
Air taken into a duct loses energy and becomes turbulent so not good.
Reason: removed quote of op
bhall
bhall
244
Re: Big Sidepods?
Turbulent convection is more efficient than laminar convection.
The reason you wouldn't want big sidepods on an F1 car is because you don't want a big anything on an F1 car.
N12ck
Re: Big Sidepods?
outer_bongolia wrote:Hi All,
so basically the idea suggested the other day which has been discussed in the MP4-27 thread, you mean that idea?
I have already done Airflow Simulations on it, which was interesting :)
Budding F1 Engineer
krisfx
krisfx
Re: Big Sidepods?
Nick, you could have at least been a little more constructive instead of being an arse about it.
I've always wondered why they haven't put the radiators closer to the rear of the sidepod with a carbon tube like they did in the 2000's It'd stop that reverse flow issue that I read about in autosport.
That's probably already been discussed.
On topic I would think the (possibly) horrible turbulent flow from the rear of the radiators wouldn't be that helpful in comparison to the other solutions we see on modern cars tbh.
N12ck
Re: Big Sidepods?
krisfx wrote:Nick, you could have at least been a little more constructive instead of being an arse about it.
when I ran simulations on such a sidepod, I found a few problems, the airflow is very turbulent exiting the tunnel, it doesnt follow the cokebottle as well as the conventional sidepods, and rapidly changes direction when it gets close to the diffuser towards the outer edges of the diffuser, whilst some follows the coke bottle (not very cleanly) I suspect this can be solved with flow conditioners, and some VG's on the exit of the tunnel, although it still doesnt get round the problem of extra drag due to the boundary layers inside the tunnel
Budding F1 Engineer
riff_raff
riff_raff
Re: Big Sidepods?
bongolia,
The huge intake would produce huge drag. The airflow over the radiator core is based on mass flow requirements. The radiator intake duct is shaped like a diffuser. It slows the velocity of the incoming air and increases its dynamic pressure ahead of the radiator core face. The exit duct is more convergent. It is designed to accelerate the discharged airflow so that its duct exit velocity is equal to or greater than the passing airflow, in order to minimize drag.
I also believe the height/width dimensions of the sidepods are somewhat controlled by regulations, since they also function as side impact structures.
slider
A: Start with a large one!"
outer_bongolia
Re: Big Sidepods?
removed.
Carl Sagan
