Dear all,
I want to know whether this project just sounds crazy of if it would be viable to actually produce it.
See below for details:
Car/ATV crossover racer.
Based on: Yamaha YFM 700 Raptor
Chassis: monocoque with spacefame reinforcing in the form of a 12 point rollcage
Body: Carbon Fibre/Aluminium
Brakes: Small 2 pot calipers for 10 inch wheels
Suspension: Double wishbone suspension
Engine: Modified Yamaha 686cc liquid-cooled w/fan, 4-stroke; SOHC, 4 valves
Gearbox: Modified Yamaha Raptor 700 5 speed + reverse
Dimensions:
Length: 2586mm
Width: 1107mm
Height: 750mm
Wheelbase: 1515mm
Target dry weight: 275 KG
Target power output + performance parts: 85-100hp
Power to weight ratio: 300hp + per ton
Performance parts engine:
Trinity Racing Stage III Powerflow intake Kit with K&N Filter
Trinity Racing Stage IV Exhaust system
Trinity Racing 734cc big bore kit
Trinity Racing Stage IV EFI Controller
Trinity Racing Heavy duty clutch kit
Trinity Racing Stage II Performance Camshaft
PWR performance radiator
Dyna FS Ignition
This was my initial quick list when i thought of the project. I was hoping to use some f1 tech in the car, but here is the issue. Is it possible to fabricate a double wishbone suspension within a reasonable buget or would i need to look at diffent tech??
