Do the vanes at the front of the barge board help the flow to follow the barge board's curvature or go over it?
Brian
I figured you would, once you understood they were at the back. Hence, the lack of explanation.hardingfv32 wrote:Absolutely correct, my mistake. I understand the function of the vanes then.
Brian
Correct. But due to its location on the step plane it is considered part of the floorCam wrote:Isn't there a regulation which states nothing can be outside the floor profile? That is, when looking at the car from below, you shouldn't see anything poking out past the floor? Or am I wrong.
those fins are okay because they're outside these specs? I wonder how far you could actually push that then. Seems like another loophole awaiting exploration.In an area lying 650mm or less from the car centre line, and from 450mm forward of the rear face of the cockpit entry template to 350mm forward of the rear wheel centre line, any intersection of any bodywork visible from beneath the car with a lateral or longitudinal vertical plane should form one continuous line which is visible from beneath the car.
Owen.C93 wrote:
