g-force_addict wrote:Would some rear outer wheel toe-in change only during cornering would be beneficial?
The rationale is the same as anti-Ackermann: to compensate for different slip angles for the (relatively) unloaded inner wheel vs the loaded outer wheel.
This could be either passive via some bushings flexing only for the outer wheel, or active via some steering linkages.
Standard feature on production cars. it is called compliance steer. If you apply a lateral force at the contact patch the rear wheel will steer in, or out, depending on where its elastic centre is. Ideally you'd apply the force at the correct location on the contact patch, in practice 30mm behind the wheel centre is often used.
At various times various companies have publicised the benefits of passive rear wheel steer, rather ignoring the fact that every car has it like it or not unless somebody accidently sets the bush rates and geometry just so.
Generally the outer wheel toes in , to increase understeer. Don't use too much, it can really upset the feel of the car. This incidentally is one reason why watts links etc are mounted behind the wheel.
