Push Rod Flex
strad
117
Push Rod Flex
Those who watched practice on Speed saw this video of the push rod flexing..
click photo
On top of everything else, would not having this kind of feedback be very fatigued to the driver?
Sir Stirling Moss
DaveW
DaveW
239
Re: Push Rod Flex
Thanks for that. An example of poor installation stiffness caused by poor design. The fact that the pushrods didn't fail (presumably) suggested that they were subjected to large bending moments through poor alignment. The bad alignment might be static (unforgivable) or dynamic caused by, for example, rocker flexing.
p.s. I wonder if their simulator models the effect....
Lycoming
Lycoming
106
Re: Push Rod Flex
I would think that the objective of pushrod design would be to have it stiff enough that its deflection is negligible. If I was writing a simulator, I wouldn't have bothered coding it in.
Interestingly, the motion of the pushrod is time dependent...
Tim.Wright
330
Re: Push Rod Flex
Looks to me like its vibrating at a natural frequency rather than being just plain to compliant. Its a problem that is not so easy to spot in the design phase.
Not sure if this would cause a change in the effective wheel stiffness or not. The vibrations are not pointing in the same direction as the load, so perhaps its not causing many handling problems.
Though for sure its not good for durability. This could easily be repaired overnight though.
Tim
mep
29
Re: Push Rod Flex
Somehow I don't see anything when i click on the photo. :?:
DaveW
DaveW
239
Re: Push Rod Flex
Tim.Wright wrote:Looks to me like its vibrating at a natural frequency rather than being just plain to compliant. Its a problem that is not so easy to spot in the design phase.
I suspect that the frequency is in phase with the kerbing inputs (the natural frequency of the suspension links should be in the hundreds of Hz).
Tim.Wright wrote:Not sure if this would cause a change in the effective wheel stiffness or not. The vibrations are not pointing in the same direction as the load, so perhaps its not causing many handling problems.
To get any significant change in push-rod length it has to buckle, so the observed motion is the signature of a change in length, I believe. Pure compressive buckling is non-linear & usually terminal, with implies a bending moment applied to the push rod, which, in turn will make the load/deflection curve (more) linear.
The change in length will be undamped, & therefore uncontrolled, which would be expected to affect Contact Patch Load control everywhere (not just when kerbing). That is quite separate from the steering shimmy caused by the kerbing event. I suspect a driver would not like the idea of a spring placed in series with his steering wheel....
DaveW
DaveW
239
Re: Push Rod Flex
mep wrote:Somehow I don't see anything when i click on the photo. :?:
What I did was: Right click on the link, select "Save Link As", then play the saved .mpg with VLC (a free media player).
DaveW
DaveW
239
Re: Push Rod Flex
Lycoming wrote:I would think that the objective of pushrod design would be to have it stiff enough that its deflection is negligible. If I was writing a simulator, I wouldn't have bothered coding it in.
And that illustrates one of the major issues I have with testing by simulator...
hollus
Re: Push Rod Flex
Thanks Dave, that worked for me. I had this issue before and had forgotten the fix.
Strad, maybe you'll want to add a "save as" next to your usual "click picture"?
Rivals, not enemies. (Now paraphrased from A. Newey).
646
Re: Push Rod Flex
a persistent train of perturbations at/near (the right) sub-harmonic of the natural frequency would do that ? (ie rumble curbing)
but would the tyre be stiff enough to transmit this torque runble (the tyres Fn wouldn't be high enough ?)
anyway, would the natural frequency (of the transverse vibration) be hundreds of Hz ?
the ends of the rod are unconstrained and it must have some relatively huge added mass effects under load
natural frequencies of hundreds of Hz are about as common as unicorns ?
Re: Push Rod Flex
brings back memories of Massas loss of suspension components after rumbling over the kerbs last year persistantly...
Jersey Tom
Jersey Tom
Re: Push Rod Flex
Looks like definite buckling to me. Wow! With it being carbon I'm amazed it didn't shatter right then and there.
mzivtins
mzivtins
Re: Push Rod Flex
Shape it like a wing = MOVABLE AERODYNAMIC DEVICE :lol:
TBH i think that although the movement is extreme in this case, all of those components must have some form of flex built in, otherwise snapping would occur much more often. Plus the whole unit seems to move as one rather than bend as such. Interesting though, and funny how the comparison to the red bull is on a different corner of the track :lol: what if the speed is 10mph higher or lower? thats enough to change the vibration frequencies considerably :shock:
Lycoming
Lycoming
106
Re: Push Rod Flex
Everything flexes, but for the most part suspension components should be stiff enough to have negligible deflection under normal operating conditions (such as going over kerbs). You don't want to have to think about a bunch of springs in series, you want to be able to think of them as infinitely stiff and ignore them. It's not like an airliner's wing, which is supposed to flex visibly, to a certain extent of course.
mep
29
Re: Push Rod Flex
Thanks for the tip Dave.
Actually, when I saw the oscillation of the part I wondered if it’s because of bad installation slackness.
That amount of movement is really not normal.
