Guest wrote:Ok ok cool idea
Just was wondering, if you wanted more downforce would modifying the rear wing (twin plane kind of thing) would not be more efficient than that flip up thing - think of the turbulence on the underside with such a camber... (I know that your figures are not to scale)
Thanks,
There is question of turbulence which I'm not sure about. I was thinking that such shape and position similar to jet engines could be a step up.
Guest wrote:Cant we also round the side pods behind the radiators?
Perhaps my drawings aren't that understandable... the sidepods ARE already already cylindrical all the way, even the outlet which is sliced - shaped like AK-47 compensator or like exhaust outlet on some F1 cars. This is only for downforce generating.
Guest wrote:Also why are you so crazy about undercutting the side pods? The only reason I can think of is to get flow over both surfaces of the under tray, in which case - why not shape it like a wing?
I’m not “crazy” about undercutting; I’m just trying to figure out all possibilities. Fully undercut sidpods are sort of plan B, moderate backup to my trimaran-Venturi concept.
They are being already cut bit by bit as the years go by and I thought “lets finish with that shy cutting and make one big final cut”.
Guest wrote:Something off the topic, but I feel that its not a bad place to say it:
I cant figure out why the old reasoning as to why a wing works has been used so extensively! You know - how the air flowing over the top has a longer path and therefore faster, therefore a low pressure on the top surface.
There is no physical reason why the two air streams should reach the trailing edge at the same time! You need to use Eulers-n equation to explain it properly. Sorry just had to get it off my chest
I don’t get it either but I think that the reason is exactly in conservative approach of radiator construction, and when you have that than sidepods look as they do…
