Is there a difference in properties between the woven type of carbon fibre and the unidirectional type of carbon fibre?
For Uni-directional carbon fibre( eg AS4/8552) the longitudinal and lateral properties differ due to difference in the coefficient of thermal expansion and also the poison ratio. This can be easily explained because the fibre is aligned in one particular direction only.
But for woven type, isn’t the property is similar in both longitudinal and lateral direction? If so, does this means that all theories applicable and developed for uni directional types are not applicable to the woven types?
