FSAE-A 2012 Curiosity...
RacingManiac
RacingManiac
The first official event of the "2013" season...
UWA brought something interesting(some pic might be from Facebook, so if you have FB filter you might have trouble viewing them):
Jersey Tom
Jersey Tom
Re: FSAE-A 2012 Curiosity...
Quite. Good on them for doing something unique. Wish I could see more of the underside of that front suspension structure.
flynfrog
Jersey Tom wrote:Quite. Good on them for doing something unique.
werd check the mounting of the fire extinguisher on the push bar. :shock:
In all seriousness wtf is up with the suspension not even sure what they are trying to do there.
Jersey Tom
Jersey Tom
I'd wager they're trying to go fast.
I started making a list of interesting points about the thing but it's a bit too long and disjoint for a post. Those 'W' shaped cutouts front and rear have more of my curiosity than the ultrashort FVSAL on the front susp, or "outboard" dampers.
flynfrog
so when I google what FVSAL means I get JTs blog and still no idea what it stands for. :?
RacingManiac
RacingManiac
The "dampers" for some reason seems to be for rule compliance.....I am still not quire sure how the chassis(the holds the engine and driver) are attached and interacted with the chassis that has the wheels....
Pierce89
flynfrog wrote:so when I google what FVSAL means I get JTs blog and still no idea what it stands for. :?
Front view swing arm length?
flynfrog
ah!
so it looks like they are attempting some sort of double chassis?
RacingManiac
RacingManiac
There are some results update on FSAE-A's FB page, curiously the UWA car is not on any of them....I am guessing here but I wonder if they deemed the car illegal....
https://www.facebook.com/FSAEAustralasia
Lycoming
Lycoming
106
Is that a cast upright I see?
mep
29
Jersey Tom wrote:I'd wager they're trying to go fast.
If you are talking about the shape of the floor, I doubt that is working. The intake should not be raised so much because it is generating lift on the front. Which means it will generate less DF, if any, than with a low intake and the balance is messed up because the CoP is far rearwards.
Jersey Tom
Jersey Tom
Nah not the shape of the floor. Look right about at axle centerline on the front susp, between the two bulkheads There's a sheet/plate metal cutout maybe 1/4" thick in a "W" shape. Also on the rear susp. Some sort of flexure force element maybe.
Not to say that any of this is necessarily good design engineering or whether or not it meets the objective they were trying to achieve, but I do like when kids are willing to do things a bit unconventional.
http://www.news.uwa.edu.au/201211075188 ... ver-design
Not much to be found about the car ...
As they have decided not to participate in dynamic tests it looks like they did not achieve all their goals .
The basic ideas reduce parts count and parts cost (less machining),increase parts functionalities (integration) etc etc is exactly what you have to do if you want to get people take notice.
RacingManiac
RacingManiac
http://motorsport.mech.uwa.edu.au/news/ ... cally.html
http://fsae.com/eve/forums/a/tpc/f/8256 ... 9520687151
Well looking forward to the explanation....
FYI the rule he was referring to:
The car must be equipped with a fully operational suspension system with shock absorbers, front and
rear, with usable wheel travel of at least 50.8 mm (2 inches), 25.4 mm (1 inch) jounce and 25.4 mm (1
inch) rebound, with driver seated. The judges reserve the right to disqualify cars which do not
represent a serious attempt at an operational suspension system or which demonstrate handling
inappropriate for an autocross circuit.
