When you drive a real wheel drive too fast around a corner, the two inner wheels lose some down-force due to mass transfer. If you oversteer, does the rear inner wheel lose traction first? And then trigger the oversteer?
If so, are there any equations to determine how the weight is distributed knowing the total mass of the car, the distance between wheels, the height of the CG, etc...?
What we are trying to do is a "split 2 wing dynaimc spoiler" that will raise its left or right half to provide the needed downforce to the rear inner wheel so that it won't slip. What we are trying to figure out is how much of the total weight is being put on that wheel, and how much does it need so that it doesn't slip. The difference will be provided by the spoiler.
Thank you in advance for any help!
