I plan to detach the front nose from the main body to be able to see all the direction and brake system, but I need your help because I haven't found enough pictures that show how the front nose camera is wired inside the nose cone and how is connected to the main body; of course the connection of the cables of the camera has to some type of fast connector that allow the replacement of the nose on race. I found a website that shows the FIA camera mountings and explains about a hole for the cable but I think that the connection to the main body solution depends on each team.
http://www.formula1-dictionary.net/tran ... amera.html
The pictures I found on Ferraris show a couple of circles on the wall that may be some kind of connectors where nose cone should be set (see image) but I haven't found any photo of the inside of the nose cose with all the cables and connections for the cam. i'm posting a photo I found without it
You can see some of my builds at this links. I try to be as much accurate as possible
http://www.f1m.com/forums/viewtopic.php?f=29&t=16326
http://www.f1m.com/forums/viewtopic.php?f=29&t=11010
http://www.f1m.com/forums/viewtopic.php?f=29&t=11612
Well, THANKS in advance because ANY picture, doesn't matter if is a f2002 or any other ferrari (also othe front nose cone images will help to undertand what happens) will help alot.
Thanks again
Edgar
