no.peanutaxis wrote:Is it because every wing has an ideal speed at which it works best, so they make multiple wings to work through the entire range of speeds that they need to produce downforce?
Exactly...infact the sucessive element is always above the precedent element....NoDivergence wrote:Look up slot effects airfoils on google. Essentially, at very high angle of attack, a single element airfoil will stall and have flow separate. By splitting this into multiple elements, the slot effect will allow re-energization of the boundary layer
