Brake pads rubbing against discs cause drag ,so you don´t want this at any cost.Usually the square shaped in crosssection caliper piston seals provide a limited piston retraction of a few tenths of a millimeter you would not be able to feel any slack in the pedal .
But then you got a car cornering at high gs ...depending on brake caliper position and hub/bearing/upright /caliper installed stiffness the loads will distort the positioning of the brake disc in relation to the caliper .Having the caliper at the bottom of the upright is maybe good for CofG but it is not good at all when cornering loads are fed into the hub/bearing assembly.
This will lead to the disc being forced a little bit from its usual line and in effect the disc making contact to the pads ...and these are knocked back in consequence .A very crude example of these happenings is a severely loose wheelbearing (taper roller design) the effect is instantly noticeable you have to pump the pedal after very short time of traveling and you get taper wear on the pads as well .
Knock back is sometimes countered by little springs behind the brake caliper pistons but you don´t ewant to do this as the drag penalty is severe -not sure how a carbon disc /pad combo reacts to permanent dragging of the pads ....I guess unpleasant...
So no negligeance on part of the mechanics it´s more a design weakness ,or better sais a tradeoff -weight vs stiffness
- in the old days they did not have ceramic bearings so the tradeoff was severe to gain stiffness ...
