F1 overlay/HUD v.1
F1 overlay/HUD v.2
And if you are afraid from the too many colors, most of the time it will look like this:
First off you will have this overlay on the right side ALL OF THE TIME. It will be gone only for replays. So you will have every vital information for every second from the race. You will have the gap from the leader for every driver in the race that will update every 2 or 3 seconds. You will have the 'laps to go' next to the leader. You will have the fastest lap holder and his result (in purple), the best personal times (in green) and a driver having problems and/or causing yellow flags on the track (in yellow). There can be other backgrounds for different cases. On the left side next to each driver you will have the used tyres sets up until the moment and the red background will notify for drivers currently in the pits. The thin green line between 2 drivers will indicate that they are less than one second from one another and DRS can be used.
Thus you will have all the information you need to know. The number of pit stops and the exact used tyres sets for absolutely every driver in the race + the gap between all the drivers (calculated manually from the gap from the leader, which is very easy to do) all in one and all of the time. (Not only for 6 drivers like it is in the current broadcast.)
In the down right corner you will have the MUCH needed picture in picture for a dynamic event like an F1 race. I can't believe that there's still no PIP in the F1 broadcasts.
If you too have some ideas about how to make the F1 overlay/HUD better don't hesitate to share them in this thread.
