By piano I mean the bumpy red and white strips on the corners. Likely they are called some other way depending on where you live.
Do the bumps increase tire wear?
Doesn't the paint make them more slippery?
What's their effect on aerodynamics as the car bounces?
Is a racing line where you are not driving over them faster?
If so, which is worse the pre-corner entry outer strip, the apex inner strip or the corner exit outer strip?
