West wrote:Anybody know the disadvantages to mounting the suspension to the side of the tub instead of a keel?
I should imagine that there are considerable structural and aerodynamic advantages to be had. Take a look at a front on shot of an MP420 - sheer motoring porn (well, almost any view of the car
Disadvantages? Shorter suspension arms, as said above with move through a tighter arc (giving more camber change at the wheel - but even that depends on what the upper arms are doing in concert with the lower ones), but you could probably argue that they will also be stiffer for a given weight.
I expect getting good front geometry would be trickier, but an F1 car does not have loads of suspension movement, so it should not be too hard to arrange a good camber curve and roll centre location. If you look at it front on, you can see that both upper and lower arms angle downwards, but different amounts, you can mentally visualise the sort of camber change you might get and roll centre position.
