manchild wrote:Second pic looks more like it...
This is a sketch of what I had in mind...
Not dissimilar to inboard rockers tried years ago (as said I think Lotus was an early exponent). As wheel rates rose, stiffness became an issue, the pushrod is structurally simpler. I have no doubt with current materials you can get plenty of stiffness, but the penalty has to be weight and it's all unsprung. Also, I can envisage that a certain amount of flex could occur (even a tiny amount could feel massive at the wheel), this flex would be undamped and creates a "spring" on uncontrolled rate.
Given how sensitive F1 cars are to ride height, I assume that absolute precision in controlling wheel movement is paramount (I have heard than suspension mounts are machined to positional tolerances of a couple of microns).
The pushrods let you place the springs dampers almost wherever you like and you can engineer almost any rising/falling/neutral rate your heart desires.
Interestingly it would seem that pullrods can be thinner and have the advantage of placing the suspension mass low down. I assume that these are not used due to packaging issues around the nose more than any other reason?
