delacf wrote:Yes, DaveW. That is my intention: Inerter, Roll damper, third spring-damper...
This might help, perhaps, courtesy of F1T's "tex" operator:
If
is the force carried by a suspension module,
is the inertial displacement of the hub and
is the local inertial displacement of the sprung mass, then the transfer function of the suspension module is:
which is a first order lead filter with
representing the spring rate, and
representing the damping coefficient,
is
is the angular frequency.
If an inerter of mass
is placed in parallel with the damper, the transfer function becomes:
which is a second order lead filter. Alternatively, if the inerter is removed and a spring of value
placed in series with the suspension module, the transfer function becomes:
which is a first order "all pass" filter. If an inerter is now added to the above, the transfer function becomes:
which is a second order "all pass" filter. Note that
is no longer representative of the displacement of the damper in either of the last two cases...
