jayathran wrote:Is it possible to have a portion of the exhaust routed to the under body to heat the air flow there and then exit at the central common exhaust under the 2014 regulations. Hence there will be more energy in the air exiting the diffuser and probably more downforce created.
This might bring a string of overheating issues if not handled carefully but looks like a possibility to my eye as I looked at the text.
Definitely..no.
1: exhaust gasses after passing through turbine lost a lot of energy
2: No leaks allowed in the exhaust ducts, all the gasses have to exit from one tailpipe
3: the only way to use them is making some tricks about monkey seat, but with more drawbacks than benefits as we know from an interview of a force india engineer (called Green i suppose). So at the moment it's not a point of interest for teams IMHO.
