Right on.
usethi23 wrote:The part you highlighted gives the chord length of the upper section relative to the lower section. Is there no other specification for the chord length? Shouldnt there be a limited range within which designers usually work?
It's all there in the regulations. For example:
From 730mm above the reference plane to the car's maximum height of 950mm above the reference plane (defined by Article 3.6), you have a zone where two closed sections of bodywork are permitted, and those two closed sections of bodywork will be your wing elements. (A "closed section," by the way, is a piece of bodywork located completely within a given area of reference. For context, an "open section" is a piece of bodywork that spans across two or more areas of reference.)
Every part of the rearmost and uppermost closed section - a.k.a. the flap - has to have a shorter chord length than the closed section immediately below it, the main plane.
You need a 10mm to 15mm gap between the trailing edge of the main plane and the leading edge of the flap.
When DRS is activated, that gap can increase to 50mm.
You need two slot-gap separators along the trailing edge of the main plane positioned so that neither are more than 355mm away from the car's center line
and so that no part of the trailing edge is more than 200mm away from a slot-gap separator.
And so on and so forth...
What you do within those constraints, and a few others, is totally up to you. So, just look through the regulations and make a box that defines the limits they describe. Then fill that box with the best goddamn wing this world has ever seen.
