Morning all,
as I am new to this forum I apologise in advance if my question is not relevant or it has been dealt with already.
I am involved in a one-make single seater series with carbon brakes. Apparently brake bias migration in the pedal release phase is an issue regardless of master cylinder combination etc. It means that brake balance is not consistent: it tends to move to the front at the end of braking i.e. when you do not really want this to happen.
It is hardly predictable although it seems related to friction and histeresys in the master cylinders. The pedal assy has been thoroughly checked and aligned and friction in the ball joints has been virtually eliminated.
I wonder if there is a simple solution to get rid of the issue. Also, what sort of system do F1 teams use to control brake bias?
Many thanks,
Boxermotor
