At the time (1975) some cars had more downforce at the front than others.
Here the Ferrari 312 T : note the front wing quite high but done in one single element with maximal width.
This started with the revisited Ferrari 312 B 3 and was taken for all the 312 T (T to T5).
Easier to operate and generate more front downforce than the typical front end of the time.
Here the McLaren M-23 aka the typical front end of the era.
We have a front end with two wings elements from each side of the nose relatively high mounted.
The total width of the two elements is shorter than the one of the 312 T. Less downforce at the front.
Interestingly one other car had probably even more downforce at the front than the 312 T at the time.
Tony Southgate's UOP-Shadow DN5 : the front end consisted of two elements but it was run much closer to the ground.
It experimented true ground effect because of the boundary layer effect. That car was very fast in 1975...
Source : Nigel Bennett, Mauro Forghieri and Tony Southgate books.
