Monocoque Bonding
ReedMann
ReedMann
Monocoque Bonding
Does anyone have any good images of how teams bond the top and bottom halves of their monocoques together? What type of joints do they use? Types of adhesive?
Thanks.
flynfrog
Re: Monocoque Bonding
ReedMann
ReedMann
flynfrog wrote:Check out this older thread
http://www.f1technical.net/forum/viewto ... =6&t=13148
Thanks for the link. I had already seen this thread. It's hard to tell what type of joint they are using. I think some teams do a single piece layup, but I know some teams still do the upper and lower half method. I imagine that pictures are hard to find as most teams keep this stuff under wraps. One of the US F1 videos also shows the top and bottom halves, but I can't tell how they interlock. I guess I'll keep scouring Google images.
ReedMann
ReedMann
Looking closer at these couple pictures, the joint sort of resembles a tongue and groove.
Based on the interview here, it seems like tongue and groove is used in sports cars.
http://www.mulsannescorner.com/bentleyelleray.html
However, they were conventional in as far as they used a top and bottom section joined by a tongue and grove joint at the waistline (just below the door aperture).
So it seems the tongue is fairly thick and the groove is rather skinny. Thoughts?
flynfrog
I think the difference in thickness is just where one side has the core and the other doesnt.
gambler
gambler
It appears that the "tongue" edges that meet each other are open to the core to allow the glue to get some tooth making the butt part of the joint stronger, maybe?
flynfrog
gambler wrote:It appears that the "tongue" edges that meet each other are open to the core to allow the glue to get some tooth making the butt part of the joint stronger, maybe?
There is no strength in that direction on the core. The tongue is to double the surface area of the bond. Tooth for a bond is kind of misunderstood. You don't need a super rough surface. You do need good surface activation and good surface wetting.
flyboy2160
flyboy2160
84
ff's totally correct about the strength direction of the core - it's only good in the direction of the cell walls. To join those very irregular adjacent core cell side walls in this type of joint, an expanding foam adhesive is typically used.
I'm surprised that the skins themselves aren't lapped over or a skin splice strip added, but maybe they aren't showing that.
hardingfv32
hardingfv32
What is a common way to surface activate epoxy?
Brian
flynfrog
hardingfv32 wrote:What is a common way to surface activate epoxy?
Brian
Hand sanding or abrasive blasting. Time is critical you lose activation as time goes on.
http://www.niar.wichita.edu/niarworksho ... 0_JimM.pdf
http://www.henkelna.com/us/content_data ... _Guide.pdf
http://www.jams-coe.org/docs/JAMS08_pre ... .Flinn.pdf
http://www.cozybuilders.org/Oshkosh_Pre ... sh2005.pdf
http://www.niar.wichita.edu/agate/docum ... -01-08.pdf
some reading if you are so inclined.
ReedMann
ReedMann
flynfrog wrote:I think the difference in thickness is just where one side has the core and the other doesnt.
The way I interpret it is that the upper half of the tub has an absence of core about an inch deep along the bottom edge. The bottom half of the tub has excess core extending about an inch along the top edge. The core interlocks between the upper and lower halves to create the joint.
Is that what you were getting at?
flynfrog
Yep. there are few ways to get the same or close to the same result. Check out the links I posted
riff_raff
riff_raff
flynfrog wrote:There is no strength in that direction on the core. The tongue is to double the surface area of the bond. Tooth for a bond is kind of misunderstood. You don't need a super rough surface. You do need good surface activation and good surface wetting.
With a lap joint between composite laminate skins, other factors like ply orientations and ply drops are also important. The relative shear stiffness at the skin and adhesive interface can affect the bond strength. That is why you would design the skin at the joint with a taper and a very thin free edge. The thin free edge of the skin minimizes the tendency of the adhesive bond to peel.
A: Start with a large one!"
Thin free?? how do you mean?
riff_raff
riff_raff
n smikle-
Sorry, I guess "free edge" was not the best description to use. A better description might be "extreme edge".
When creating an adhesive lap joint, the extreme edge of each panel should be tapered as thin as practical so that it has no bending stiffness. If the extreme edge of the panel at the adhesive bond interface has very little bending stiffness, it won't be able to peel at this location.
