Hello, all.
I'm looking for some orientation regarding how to calculate Roll Centers (first, IC's and finally the Roll Center, for each axle) of a double wishbone assembly as can be found here:
http://www.steerbythrottle.com/hccyong/ ... SIGN~1.HTM
or more specifically:
http://www.steerbythrottle.com/hccyong/ ... Image3.jpg
and
http://www.steerbythrottle.com/hccyong/ ... mage58.jpg
From a front-view perspective, RC's seem apparently straightforward to find:
- extend lines from upper control arm and lower control arm, check their intersection point
- do the above for both sides, in order to find the IC's
- from the IC's, extend lines to the center of the contact patch of each tire
- where these lines intersect, we should find the RC's
Problem is:
- on a double a-arm assembly as depicted in the site dedicated to a SAE car, each arm (upper or lower) has 2 different mounting points to the chassis
So, how are the lines from upper and lower arms drawn in order to check their intersection points (IC's), taking into account the mounting points to the chassis?
Thanks in advance for any help on this.
