hello guys,
i need please to ask something, while reading the regulations trying to figure out the geometry of the roll structure behing the driver so the regulations says, that the structure should be 940mm at least from the reference plane, and in the upper bodywork section 3.16 it says that the height of upper bodywork should be 925mm max ! so how is that possible if the limit is 925 and it says 940 for the roll structure ?!!
here are picture of the section
