http://www.f1technical.net/news/19868
Also seems like drivers are allowed to go to pits to change tyers when VSC is out.
"Drivers will not be allowed to enter the pits, unless it is for the purpose of changing tyres"
+1 on that!Trocola wrote:How easy could be to use a speed limit like they use in pits? But that seems too easy for the FIA. They say there is a delta time, and a beta time, and a... and then, when someone goes faster, the team will say thta there is a loop hole on the rules that allows you to go faster if it is raining, becasue on the rules does not say that you must go slower than the delta time when it is raining....
How stupid and complicated they are making F1
Agreed it's a bit complicated, but it is the exact same situation as right now under a normal safety car. You may or may not know that when the SC is on track and cars are not in the queue yet, a maximum sector time is displayed on each drivers' dashboard to avoid them racing to the pitlane, as that would obviously create a safety risk as well. It's a good enough system, and really nothing to worry about for the regular TV spectator.Trocola wrote:How easy could be to use a speed limit like they use in pits? But that seems too easy for the FIA. They say there is a delta time, and a beta time, and a... and then, when someone goes faster, the team will say thta there is a loop hole on the rules that allows you to go faster if it is raining, becasue on the rules does not say that you must go slower than the delta time when it is raining....
I think that's a problem. If you are driving an F1 car, you can't be looking all the time to a tiny screen to see if you are going too fast. You put a 100km/h speed limiter, just like in the pits, from marshall point A (waving a new type of flag to inform that you have to activate the limiter) to marshall point B (where a marshall will inform about the end of the limited-speed zone) and there will be no problem with speeding.Steven wrote: Agreed it's a bit complicated, but it is the exact same situation as right now under a normal safety car. You may or may not know that when the SC is on track and cars are not in the queue yet, a maximum sector time is displayed on each drivers' dashboard to avoid them racing to the pitlane, as that would obviously create a safety risk as well. It's a good enough system, and really nothing to worry about for the regular TV spectator.
A speed limit for a certain marshall sector has been tried as well, but it was deemed too risky, as drivers would race and brake at the very last moment to gain that little bit of time. It's inherent to motorsports that drivers will push, and under dangerous situations, sometimes a complicated system is all that is left to ensure safety.
Steven wrote: A speed limit for a certain marshall sector has been tried as well, but it was deemed too risky, as drivers would race and brake at the very last moment to gain that little bit of time.
