Can the diffuser entrance (the place in the underfloor where the diffusers begin) be wider than the venturi tunnel width between the wheels?
Like this
Doesn't the narrowing after the wide entrance cause air to compress when you actually want it to progressively expand?
Can you overcome this by increasing the tunnel height after the wide entrance so that transverse area progressively increases?
