Flexi wings 2015
hollus
Flexi wings 2015
They are at it again.
These are two frames, at low and high speed, extracted from this video, around the 2 minute mark.
https://www.youtube.com/watch?v=fWqsrxbol_k
The info overlay provides a really good frame of reference:
I am sure there are plenty more examples...
Rivals, not enemies. (Now paraphrased from A. Newey).
radosav
radosav
Re: Flexi wings 2015
How big is difference of aerodynamic load between 100 and 300 km per hour ?
Maybe flexing is within rules ?
hollus
Flexing, as measured in the tests, is definitively within the rules.
But I don't think that this flexing is measured at the end of the flaps under a large horizontal force.
For reference: "These are not the flimsy linkages you are looking for"
https://twitter.com/AlbertFabregaCA/sta ... 4668532736
bdr529
59
it does look like it's moved down a bit from the two photos, but I don't know if it's the whole wing flexing or the one element in front of the camera that is twisting back into a flatter profile in the bottom photo
hollus
The video shows it much, much better. Around the 2 minute mark.
radosav
radosav
hollus wrote:The video shows it much, much better. Around the 2 minute mark.
Yes, and around 2:10 when car hits curb it moves a lot more! It behaves like it is controlled by spring !
ecapox
Wow!
hollus wrote:They are at it again.
They never stopped.
Jolle
Jolle
133
Looking at the video, it's what you could expect in the difference in load between 80 and 310 km/h. The real flex wings were those where the underside was almost touching the ground.
The flexing on the curb is more about the way it's constructed. They are very stiff with loads in the normal direction. I imagine you can stand on it and it wouldn't move while wou can almost tear the strips off when you pull it toward/up, simply by hand.
FW17
170
CHECK out whats going on in LMP1, guess this Has Just been banned
FIA in F1 used to do a CHECK only on the wing without the pylon and nose
Never seen so much deflection :shock:
bdr529
59
WilliamsF1 wrote:CHECK out whats going on in LMP1, guess this Has Just been banned
http://www.mulsannescorner.com/ToyotaTS ... ation2.gif
Thank you WilliamsF1, good visual to show what I think is happening
It specifically says Toyota wing, aka WEC champions, were the others in on it too?
bdr529
59
Sevach wrote:It specifically says Toyota wing, aka WEC champions, were the others in on it too?
I did know that was a Toyota wing from WEC, but it was showing visually what I was trying to say in my first post
bdr529
Sorry if I confused you, I should have taken the time myself to find a gif of a F1 wing showing the same thing
Blanchimont
Blanchimont
214
